I'm going to make the plug and use a buddies vac machine to pull the canopy. Will have to do it in two pieces but that will be OK as I might leave it open at the rear. I do have a larger skin packaging machine with a 18X24 vac table and frame. I need to do some work to it but it might end up working good for the larger canopies in the future. It is 3ph though and I will need a phase converter to get it up and running. That's a whole other project!
