Originally Posted by
oldbassard
One major thing I can think of that could cause this problem and is a simple fix is, the gasket or gaskets between the carburetor or reed valve and engine block could be sucking air. I also bought a Chinese engine, the first thing I did was to replace the carburetor, and put a Bowman ring in mine. The jury is still out on whether or not I replace the CDI.
When I bought a Bowman ring, Frank Bowman inserts a notice into his packages that tells you that the Reed valves on these Chinese engines are notorious for having mold flash left on them which prevents the Carburetor or engine block side from sealing. You might give it a check before you throw in the towel. Good luck
I have to second this.
I have an RCGF 15 that would not pull fuel even with the choke full on. When i bought a ring for another engine from Bowman he included the note. I disassembled the engine and cleaned up all surfaces and sealed them with silicon seal.
Now the engine starts and runs like a champ. It sure is tough to break in though. I should have got a Bowen ring for it too.
