Originally Posted by
USSCAT
I am working on he nose wheel and doors, frankly I need some advise as how to attache the front nose wheel door to the retract. I remember seeing a few posts about that but can not find them. Here is a few photos, I have installed the hinges, the doors will come off later to install a layer of white styrene for looks. Any help and tip is appreciated.
Mike,
CJM has a nylon door attachment that clips around the strut. A combination of one of these and a short piece of brass tube attached to the door span wise with a U shaped wire going through the brass tube and attached to the nylon block should work. Lets you hook up the door mechanically and still have steering. Just a thought.
