RCU Forums - View Single Post - CJM F-4D Conversion and Build
Old 12-29-2013 | 12:23 PM
  #84
USSCAT's Avatar
USSCAT
Ok, taking Ronnie's and Ravill's suggestions, i think I have the problem licked. I used a piece of Teflon stock and drilled to the ole diameter with a slight opening to get it in and out. Then modified a robart large hinge by cutting it to size on one side and drilling a small hole on the other side for pivot. the teflon block rides freely on the ole shaft. Here are a few pictures.....
ID:	1952307   Click image for larger version
ID:	1952308   Click image for larger version
ID:	1952309   Click image for larger version
ID:	1952310   Click image for larger version
ID:	1952311   Click image for larger version
ID:	1952312   Click image for larger version
ID:	1952313   Click image for larger version
