RCU Forums - View Single Post - What should I do, buy or rebuild?
Old 12-31-2013 | 04:57 AM
flyinwalenda's Avatar
flyinwalenda
Originally Posted by djsqueeze
No, 52larry52. I am going to take everyone's advice and rebuild. Thank you guys for the advice, esp. you, flyinwalenda
for the instructions (which is what I was also looking for). I will post more pics as I go step by step.
You need to make it strong but try not to go overboard with a lot of epoxy making it really tail heavy. Try and use CA where you can and epoxy the triangle stock on. I don't remember how these came out of the box (tail, nose heavy or neutral) but you can always move the battery forward to compensate or put on a bigger engine!
Oh and if there are rough spots, pot holes.divots, in the balsa after repair get a small container of lightweight spackling compound , fill in the dents and sand smooth . Then you can cover the sins with a piece of coating or paint it.
