RCU Forums - View Single Post - What should I do, buy or rebuild?
Old 01-02-2014 | 06:24 AM
  #33
flyinwalenda's Avatar
flyinwalenda
Originally Posted by djsqueeze
flyinwalenda
I am using tri-cycle landing gear so it is on the nose heavy side. It gave you options for a tail dragger or tri-cycle gear. I chose tri-cycle gear. (Don't remember why, probably had something to do with my trainers.)
I have some spare wood. I am going to try to make some extra pieces to use as braces.
On the right side with the most damage, I would cut that out back to the first former/bulkhead and replace it with a new piece of balsa. If you can;t repair the other side replace it too. Cut some plates out of light-ply if you have or use some square stock to reinforce the joints of the new pieces up against the former on the inside. You will get it . Just take your time ,think about it a few times, measure twice,cut once, etc...
