Just checking ... you're sure that's an Ohio, right ?
The reasons I ask are that
1) Ohio did not do an 84" Sukhio
AFAIK - they did a 69" [kit number 140] and an 86" [kit # 130] (not being petty over 2" - just trying to be sure its the same kit).
2) You said you really like the cowl... I have the 86" Ohio SU-26mx, and the cowl was an abortion. I actually have more hours in the cowl construction than in the rest of the aircraft combined. It was three pieces of fibregalss that didn't even come close to fitting together, with a whole load of ABS louvers attached.
If you do have Ohio kit # 130, I may be able to help. I can get the rudder and elevator throws from mine, but can't get you the aileron throws - that's because the model is temporarily in storage, with the wings and fuz in separate locations. Depending on the RX battery status I may need to charge before taking a measurement, but if you are willing to wait a bit for the elev & rudder info, I'll do that.
BTW, you can see a couple of pics of mine in my member's gallery. It's G-62 powered.
Regs,
Gordon
