Originally Posted by
toolmaker7341
You never did say if you wanted to build or buy an ARF. If you want to build I recommend the Balsa USA Stick as the only building involved is the wing. If your unfortunate to have a crash you can repair it easily even a new wing kits is $20.00. It can be flown with a ,25LA to a .45 whatever. It is a realy sweet trainer with the .25 I have one that is 27 years old and flew it with a Fox .25 baffle motor (less power than an OS.25 LA) including carring a 35mm camera. Check it out. Not pretty but covered with your favorite color transparent covering it is a beautiful site with the sun shinning through.
Thanks for your input, Mike. Sorry I wasn't more clear to start. Actually, I have so many challenges (beyond the vision, my left arm is partially paralyzed and neck fused), that I think I better start out with a tried and true RTF. However, FPV is something I'm dreaming about - for later on.
Trish
