RCU Forums - View Single Post - how to hinge a thick aileron?
Old 01-11-2014 | 02:43 AM
TomCrump's Avatar
TomCrump
Originally Posted by ARUP
Add stock to aileron LE then trim the aileron TE after 'top hinging' so that the TE of aileron matches that of wing. Now, sand the LE of aileron to allow for 'down' travel.
For top hinging, on these ailerons, I would use Dubro flat pinned hinges. The Robart hinge points have a certain degree of difficulty in installing them properly in this application. http://www3.towerhobbies.com/cgi-bin...?&I=LXD941&P=0
At this point, if it were me, I would draw a line down the center of the length of the leading edge. I'd use a sanding bar and bevel the LE, leaving the line as the pivot point.
The aileron looks to be built per instructions, and Bax states that it will provide enough aileron movement.
If it doesn't, lispro can cut off the leading edge, and modify his ailerons to mimic the construction of those that I posted above, or follow your suggestion.
Your way may be a little easier than mine.
