RCU Forums - View Single Post - how to hinge a thick aileron?
Old 01-11-2014 | 03:08 PM
Granpooba
Originally Posted by TomCrump
For top hinging, on these ailerons, I would use Dubro flat pinned hinges. The Robart hinge points have a certain degree of difficulty in installing them properly in this application. http://www3.towerhobbies.com/cgi-bin...?&I=LXD941&P=0
At this point, if it were me, I would draw a line down the center of the length of the leading edge. I'd use a sanding bar and bevel the LE, leaving the line as the pivot point.
The aileron looks to be built per instructions, and Bax states that it will provide enough aileron movement.
If it doesn't, lispro can cut off the leading edge, and modify his ailerons to mimic the construction of those that I posted above, or follow your suggestion.
Your way may be a little easier than mine.
DITTO ! The Dubro hinges have always worked for me.
