RCU Forums - View Single Post - New JR28X
Thread: New JR28X
Old 01-15-2014 | 11:03 AM
kochj
Anyone think there is a use for a 2-stage transmitter sticks???
EXP: Initial pull, puse ect, is 1-spring tension
Then as you move the stick to the outer position, it becomes NOTICABLY harder...
One could use this (2nd part of stick movement) to trigger something...like low-to-High
Throws...>?????????????????
I realize there is triggering through stick movement, but not a stage at which you KNOW, when you have hit the area in movement, by increasing the tension.
