RCU Forums - View Single Post - SE5a alignment problems
Old 01-20-2014 | 01:36 AM
abufletcher's Avatar
abufletcher
Originally Posted by mikeywart
It looks to me that if the fuselage is indeed level, that the upper wing has positive incidence and the lower is
at "0" or negative.
I don't recall at the moment the incidences designed into the model. I just built it the way it was designed. But yes the top wing is definitely positive relative to both the bottom wing and the engine thrust line. The elevator also appears to be positive.
