Thanks David
I need to solder a washer onto the brass spacers to keep them from pressing into the ply. When I drilled the holes I wasn't thinking ahead far enough by drilling it from the backside just deep enough for the blind nut, then clearance the rest of the way through. I won't make the same mistake before I glue the mount blocks into the wings. The right wing panel came out of the jig with a slight bow of <1mm tip to root at the spar. I'm not sure if I should worry about that, but I may try and get it out anyway before I start on the left panel. Thoughts on that anyone?
Dave
