On spectrum you can only use a aux channel, not gear. If you are running a duel elevator 1 goes in elevator and the other in aux 1 port. In the basic en set up window you need to go into wing configuration and change to duel elevator. After that then you go into servo set up; scroll thru all of the options, you will have L elevator and R elevator, one of them you will have to reverse one of them.
