RCU Forums - View Single Post - Flying fish pics ( modeltech)
Old 01-21-2014 | 08:43 AM
ARTURO_FERRARIN
Originally Posted by doxilia
Arturo,
if you have any questions, we are probably able to answer them. As mentioned above, you'll ideally want a rear exhaust engine and tuned pipe. It looks like its setup just like Prettners Magic with a S-shaped header (accopiamento) and pipe (risonanza) running down the inside if the fuse top.
Trike retracts and 5 servos+ (6 or 7 the retracts need one or two, 7 or 8 if the engine needs a high speed adjustment like a NovaRossi 9 mm carb). Incidentally, NovaRossi makes a very nice engine and header that should work well on the model.
Davide
Hello,
thanks for help and forgive my late reply... I was too busy building the flying fish... nooo I am jokeing.
I will take some time to begin the construction.
I am far from my workshop as I work abroad. In any case I will post pictures whenever I will build the flying fish.
Regards, Arturo
