Looks great! Really makes me want to put mine on the board, like... now! I sure don't need to start another project until some get out of the way! As others state: the longer the nose then the less right thrust is needed. Similar thing holds true for changing thrust up or down. High wing needs down thrust and a low wing could use up thrust. Average multiwingers thru thrust line to get starting points. Flight envelope experimentation determines what is desired.
