RCU Forums - View Single Post - DLA 32 ignition question
Old 01-25-2014 | 07:05 AM
coralcape
Access the sensor leads from the ignition and with ignition on, short the white wire to the black wire momentarily. Should get a spark. If not generally the ignition unit is defective, assuming good battery supply. If you get a spark, hall sensor is defective, or sensor to magnet gap is too great. Good luck, red
