RCU Forums - View Single Post - Bashing a bashed kit
Old 01-25-2014 | 11:46 AM
RDJeff
Now to the really fun part, the fuselage! Since this plane will be a high winger, I thought about just flipping over the sides that came with the kit, but I figured I needed a bit more fuselage length, so I found some 48" pieces of 3/16" balsa, and used every bit of that length. The kit pieces are only 39 1/2" long. This should help with stability and control authority.
I started off by transferring the kit fuselage outlines onto my bigger balsa sheets, then cut them out. I used 1/4" birch plywood for the floor and bulkheads, and added the blind nuts for the landing gear mounting. Next, I added the kit style formers to the fuselage.
ID:	1961941   Click image for larger version
ID:	1961943   Click image for larger version
ID:	1961944   Click image for larger version
ID:	1961945   Click image for larger version
ID:	1961946   Click image for larger version
ID:	1961947   Click image for larger version
ID:	1961948   Click image for larger version
ID:	1961950   Click image for larger version
ID:	1961951   Click image for larger version
ID:	1961952   Click image for larger version
