I think if you can manage to set the model on it's sides with the centerline secured in a level position you can use the robart inc. meter to check and adjust the engine thrust line. I haven't felt the need to do this in a long time and as I recall the "jigging" the models' centerline level was the part where a little creativity was needed.
