Originally Posted by
FireBee
Your starboard prop side needs to be shorter. I'd say about 1/8 th to 3/16 th ( less than 1cm) or something about in that range
Even after all my work, the starboard side measure is still only 1-2mm shorter. It's sort of annoying. I suppose it's gotten maybe 4mm shorter when you remember than it used to be +2mm (not degrees) on the port side. Given the way the engine is mounted between two ply "shelves" I'm hesitant to enlarge the bolt holes an further to allow more movement.
