You dont need 100% coverage of the pins, as long as 3/4 of it is in the wood you will be fine. A plus to it is if you get a glob of Epoxy on the pin outside the wood block it will hold it even better. You can add the to block if it makes you feel better, but you are just going to be adding weight to the tail which is not always a good thing.
