RE: Advise on Pitts or Ultimate Pls
I have the Lanier Pitts built from the kit. It is a laser cut kit that builds quickly and easily. The main disadvantage is it comes with plastic cowl and wheel pants. Fiberglass are available though.
It is flying with a 2.4 and weighs around 12lbs so when the engine decides to run right it will be a good little bipe.
Also another bipe to consider is the super stinker that Midwest (I think) kits. You can still find those for sale. It is about the same size.
Good Luck
V-Snap
