RCU Forums - View Single Post - New 3 axis stabilization in testing
Old 02-02-2014 | 07:07 AM
  #54
JohnB96041's Avatar
JohnB96041
Need some programming help. Trying to setup a DX8 transmitter with the Eagle Tree Guardian 2d/3d. Would like to have the Flap/Gyro switch set up as 2d/off/3d. Currently all my controlls work as directed with stick movement. Aileron (2 servos), Elevator, Rudder all move in the correct direction. When I move to 2d and raise the tail the elevator moves up. Right and left move the rudder in the correct direction for correction. Aileron is a different issue. In 2d mode, stick movement moves the Ailerons in the correct direction. However, If I roll the model left or right, both ailerons move in the same direction. Either both move up or both move down. How in the world do I correct this?
