Originally Posted by
Jim Hargett
I recently purchased a used set of Goldberg Super Floats, which were covered with a layer of
gray-colored MonoKote. The previous owner also applied a layer of clear MonoKote over the gray-colored
MonoKote.
My plan is to remove both layers of old MonoKote, fill and sand any cracks, apply a coat or two of silicon
sealant over all surfaces of the floats, cover with a new color of MonoKote, and then cover the new color with
a layer of clear MonoKote.
Is my plan sound? Am I leaving anything out? Any advice would be much appreciated.
jim
flybyjohn
Jim, I do not know what kind of silicone sealer you are talking about using but I do know that most things will not stick to silicone sealer and I am guessing monocote is one of them. I would use a different kind of sealer and stay away from the silicone if you ever want to put anything over the top of it again.
Nothing will stick to cured silicone. Not even silicone. I worked W/sealants in comercial glazing & the ONLY application where silicone was (correctly) used was metal/glass joints.
