waterproofing floats
IN
I am building GP floats, and I have a question...
Can I waterproof the floats with a clear laquer and then monokote the floats? Will the monokote stick to anything?
I have never covered anything yet, so I don't know how monokote works...
Please help!
Please help!
My Feedback: (26)
WI
I built a set of Goldberg Superfloats for my Cloud Dancer 60 which are also built up floats. I was careful to fill and sand any cracks before covering them with Ultracote. I made sure there were no gaps then just covered them with the Ultracote. I never had a problem with water getting in. They always worked great!
My brother and I both covered a set of GP floats with MonoKote and we had good luck. We first cut some 1/2 inch wide strips and used them to cover each joint (1/4 inch on each side). Then we covered each surface. This way we had 2 layers at each joint. Had no problems. Even used them on snow with good luck........Seaplane
I recently purchased a used set of Goldberg Super Floats, which were covered with a layer of
gray-colored MonoKote. The previous owner also applied a layer of clear MonoKote over the gray-colored
MonoKote.
My plan is to remove both layers of old MonoKote, fill and sand any cracks, apply a coat or two of silicon
sealant over all surfaces of the floats, cover with a new color of MonoKote, and then cover the new color with
a layer of clear MonoKote.
Is my plan sound? Am I leaving anything out? Any advice would be much appreciated.
jim
MonoKote.
jim
Goinstraightup:
Thanks for your comment. Although some members of my club are encouraging me to fiberglass my floats,
I think I'll follow your suggestion instead, though I will likely apply a coat or two of silicone sealer before putting on
the MonoKote or UltraKote. Thanks again.
jim
jim
MT
Jim, I do not know what kind of silicone sealer you are talking about using but I do know that most things will not stick to silicone and I am guessing monocote is one of them. I would use a different kind of sealer and stay away from the silicone if you ever want to put anything over the top of it again. I know that painters hate armorall because it has silicone in it and they can never seem to get it off before painting and paint won't stick to it. I have heard of using water based poly to seal the wood and then covering with monocote. I have done this with mixed results. I don't think I let the sealer dry enough and had problems with it bubbling under the monocote when I applied heat to it.
MonoKote.
jim
MonoKote.
jim
Jim, I do not know what kind of silicone sealer you are talking about using but I do know that most things will not stick to silicone sealer and I am guessing monocote is one of them. I would use a different kind of sealer and stay away from the silicone if you ever want to put anything over the top of it again.
Good ol' Pactra dope works well as a sealer and film coverings stick to it and WON'T come off.
Water Based PolyUrethane works well, too. Before you seal, Bondo or lightweight spackle fills the cracks, and the sealant seals the spackle so it won't get gooshy.
If you glass the floats, use your fingers the smear a thin but visible coat of spackle over the glass cloth, then take it down to the glass cloth with a fine sanding block.
In olden days we used to make a paste of Talcum powder and clear dope as a sealer/ filler, then sand that down slick before putting on the final gloss coat.
Jim and Roger:
Many thanks for your thoughtful advice!!! I am a total newbee when it comes to float flying,
so all the suggestion here help a lot. Just FYI, I have a set of Goldberg Superfloats (used but in
good shape) that I plan to install on a Goldberg Anniversary Cub with an OS 91 Surpass engine.
Thanks again. Jim
PS: Jim Casey: Just looked at your website. Wow!!! Very cool and extrememly useful!!!!
Thanks again. Jim
