Hi CADtech,
Since we took over the Futaba Service center in 2000, we have never seen a blue stickered receiver crystal on 75mHz.
As for the regular and "short" crystals, there is no physical size difference, it is only the internal makeup of these that is different.
I would suggest that you do a range check before using this crystal. or if you are in doubt, I would purchase a completely new set.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
http://www.futaba-rc.com)
