RCU Forums - View Single Post - Basic Skils: Turns using rudder
Old 02-19-2014 | 05:44 AM
jester_s1
Moderator
It sounded to me like he meant that the trainers required some opposite aileron when he uses the rudder to turn. That's true if you initiate the turn with the ailerons and then feed in rudder, since those planes have such a strong roll coupling with the rudder. A rudder only turn will work fine with those planes, but if you roll into them and then input rudder it will make them roll too much.
