RCU Forums - View Single Post - Jettronics setup
Old 02-20-2014 | 02:21 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by Dave Wilshere
Don't program the valves! reset pressing the buttons 5 times on switch on. Increase the travel to 105% each end and go...
But a servo tester is a good test as it gets rid of mixes etc
Isn't the reset to default sequence for the 2 button version to press and hold both buttons for 3 seconds and then apply power?
Originally Posted by Justflying1
Have you asingned the switch on the transmitter with the port on the receiver you have the valves in. I run Spectrum and JR and never needed to buy anything special to make my valves work. Maybe I'm the special one as I have never had a brown out either with Spectrum or JR products. LOL.
I have several Jettronics valves (dual and single) that I use with JR Power-safe receivers and some work erratically and the others do absolutely nothing unless used with signal boosters.
