RCU Forums - View Single Post - Jettronics setup
Old 02-21-2014 | 03:09 AM
Mylo
I also suspect that it’s either a leaking piston, a blocked/kinked airline or possibly an incorrect setup.
Disconnect the airlines from the valve and connect to a standalone actuator. If this works, then the valve(s) is OK and the problem lies further downstream.
Good luck, I’m sure you will find the problem.
