Originally Posted by
Dig it
Its not the gear, I've soap tested the entire system.
Just looked at your pic, Dave is correct, there should be 4 nipples on a dual action valve. 1x air supply, 2x cylinder connections and 1 vent. It appears the pic is of the low loss brake valve? What are you driving with it? If it's on your airbrakes or gear, it's a problem.(unless your gear is "spring down") It's only good for the wheel brakes. Mike
