I have a single action because the retracts are air up/spring down. I was told this would work just find for the application, perhaps not. The gear are 5 or 6 years old but never been used as is the kit. I was going to upgrade but didn't see the necessity given I'm sure people had many successful flights on these old Behotec gear.
Justflying I have been pressure testing for 20 years and I can assure you it is the correct way to do it.
I'll take a few things apart and test them separately. I've never tried to use this type of valve for this application so it very well could be that it is not what I need. I'll also cycle the gear with an ordinary air valve to see how they are functioning. Once again the air is not coming from the gear itself.
Thanks all
Dale
