RCU Forums - View Single Post - Wing Section for a New Bipe.
Old 02-22-2014 | 09:25 PM
  #47
MTK
Originally Posted by serious power
Hi,
Just a little more detail.
Top and bottom wing core weights were 65g and 70g prior to honeycombing.
They are now at 27.5g and 32.5g respectively.
The wing skins were 30g prior to sanding and they are now at 26g with 0.2oz carbon veil applied - to the inside.
Brian
Brian, the panel weights are about what I thought you'd get. So 2 skins plus the core you are at just about 75 to 80 grams each panel. Expect about 20-25 grams of glue and these should come in at around 100 grams each panel. Each wing most likely will weigh about 200 to 230 grams plus center reinforcement. I think these are plenty light enough to this stage. Depending on type of finish, I believe they shouldn't be much heavier than 330-350 grams, ready for servo and linkage. Fine job!
Let me suggest that you go over the veil carefully and glue down any bubbles.
