RCU Forums - View Single Post - Basic Skils: Turns using rudder
Old 02-24-2014 | 02:34 AM
  #81
HarryC
Originally Posted by speedracerntrixie
Harry, where in my post did I say I was doing a flat turn? What I said it that it is common place to hold rudder to maintain ground track. .
you want to keep the airplanes track parallel to the runway. Using rudder to do this will not result in a downgrade from the judges. Leaning the wings into the wind will result in a downgrade.
I took you to mean that if your model wasn't flying parallel to the runway, you used rudder alone to change the line and avoid being easily seen to be making a turn. Are you actually saying that you hold on into wind rudder all the way along a "straight line"?
