RCU Forums - View Single Post - Saito FA 82b throttle linkage problem
Old 02-26-2014 | 01:49 PM
rlipsett
personally I would have used a cable throttle connection it allows you shift the connection out on linear alignment without binding. you would have had to changed where the pushrod came out but as long as the cable does not travel an extended distance from the guide support the throttle works great. I started using them when I had slight binding in my 3d planes. I only noticed it when doing very minor throttle adjustments in hovering and the cable system worked better
