Thanx i got the crank out but the bearing casing was not as easy as tapping out.
Here is a new trick i call the ice trick, lol
Simply heat your engine casing, doesn't matter what method i simply used a gas torch, then i used some ear buds soaked in cold ice water, when you've heated apply cold water on the bearing ring alone, to shrink it slightly, i still had to pull it out with a long nose pliers.
hope this helps someone.
