RCU Forums - View Single Post - Engine troubles
Old 03-03-2014 | 08:34 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Using a torch can warp the case. You always want to heat the crankcase evenly thus my suggestion to use the oven. I've never had to cool the bearing race to get a bearing out. The aluminum has a much higher expansion rate than the steel bearing so it shouldn't be necessary to cool the steel parts down. In the end you got the bearing out and that's the important part.
