Speed, the issue I have with what you are proposing is not whether or not a plane can be operated in a manner inconsistent with full scale flight, but whether or not you need to understand how it works. Models and full scale alike will spin if you enter a Stall with enough yaw, and if you don't understand what is happening you will most likely use the wrong inputs to correct it. That is just one reason it is advisable to learn how and why aiplanes fly
