RCU Forums - View Single Post - Basic Skils: Turns using rudder
Old 03-05-2014 | 05:44 PM
  #194
bjr_93tz
Originally Posted by Bozarth
Are you saying that you set the transmitter up so that the typical aileron input (right stick in mode2) results in nothing?
Kurt
Tough call on that one. Traditionally the rudder is operated from the aileron stick on a 3-channel plane but this has caused minor problems down the track when switching over to 4-channel planes and the "aileron" stick now won't keep the plane straight on takeoff or on a bungie/winch requiring the previously unused rudder stick to get some action. I can see the reason for having it "correct" from the start but it might be a mode I vs mode II human factor thing?
Now I'm experienced (?) I set up my 3 channel planes with the rudder on the correct stick BUT mix it over to the Aileron stick as well so I've got rudder on both sticks. Sometimes I find myself holding in a bit too much rudder and a bit of opposite "aileron" during a thermal turn like I do with the DLG ????
