I use both types with equal success. The nylon ones are larger and may not "look" right on some models where the metal ones are a bit slimmer. Use the ones that you think look best on your model. If using the metal ones with metal pushrods make sure you use nylon horns so there is no metal-to-metal contact/vibration.
