Epoxy curing temperatures
Hello all,
I was just ready to mix some epoxy and thin it out with denatured alchol to fuel proof my engine/firewall area and read on the epoxy bottle "Must be cured above 70 degrees F). I don't even keep my house above 70 degrees, never mind my basement workshop. With this said how do you resolve this issue? I would like to build in the winter. If I can't use epoxy to fuel proof what other products have you used that would serve the purpose? Is polyurethane any good?
Thanks for you input,
Pat
