Epoxy curing temperatures
My Feedback: (29)
Thanks Rodney, I appreciate the feedback. The OP simply stated if he needs to follow the directions on his packaging and we tried to give him the answer and reasoning behind it. Unfortunately RCU is famous for guys with limited experience wanting to argue points without fully understanding the situation. West epoxies are formulated for cold cures because they are intended for boats that may still be in the water or not able to get to a warm environment. Hobbyists like it because it is user friendly and it does the job. My last race airplane would not be the same if it was not built with materials and knowledge that go beyond common hobby. It has 520 sq in of wing, weighs 6.25 lbs and is powered with a YS 115. First off the weight would be almost impossible, the engine weight is 1/3 total aircraft weight. Figure in radio gear, retracts, 16 oz fuel tank, full paint job and you can see what I mean. The fuse is laid up using a surface layer of 2.4 ox cloth followed by a layer of 6 oz cloth with 3K CF tow between the layers in the nose and wing TE. Thats not a lot of material there yet the airplane does an honest 160 mph and will do a 180 degree turn in 50' dia. That is right around 20 G's. The fuse also has no formers, not even a firewall. What makes it work is that I used Hysol 9396 resin and then post cured the fuse at 180 degrees for 2 hours following an ambient cure of 48 hours. Once you have the knowledge of composites you will find areas to use the knowledge.
If you really understood what speed was saying, you would realize that he simply meant they post cure all epoxies @ 160 degrees without spelling it out for you, plain and simple.
The caution label from West Systems is really for the unknowing hobby types because there are many manufacturing applications that require heating epoxy resins well over 120 degrees as part of the processing.
You have stated heat is only used as a processing means to decrease the cure time when utilizing pre-pregs as your manufacturing media. You might consider staying away from entering into disagreements on a subject you have clearly illustrated you possess limited knowledge of.
Bob
Bob
As to the West System web site the manuals, videos and general information is much more informative than the self posturing and poor attempt at putting down any who would dare to offer an opinion that might run contrary to the grand Wazoo and his elf.
Dennis
The advice from a few of the other non experts like using a heat gun or putting it in a heated area is enough to address the OP’s concern. Simple but effective. Going on about how big an expert you are adds nothing as far as I am concerned of value. It seems every time someone asks what should be a simple question there are those who feel the need to convince everyone they are the true messiah of what ever is being discussed. If there are several so called experts then look out the next 30 pages of posts are spent all of them trying to out do each other with their knowledge on the subject. Meanwhile the OP has fixed his problem, moved on and most likely is out flying never to bother to return to the topic again.
What ever happened to answering a simple question with a simple answer without all the chest pounding? It’s like a clip from the movie Spaceballs “I see your Swartz is as big as mine.”
http://www.youtube.com/watch?v=RI0i_tL-8aU
My Feedback: (29)
Now Dennis, you seem to be getting a little personal there bud. Tell ya what, lay up a couple piles of cloth between some mylar or plastic bag with your West Systems wonder epoxy and let it ambient cure for 24 hours. Check the flexibility. Then place in an oven set to 150 to 175 degrees for 2 hours, let cool and check the flexibility again. I don't have to guess what you will find out. I understand if you don't want to take the time to prove my point but if you choose not to then please leave the thread and let us teach something to the guys who would like to learn.
PS I love that movie........My hair, he shot my hair LOL
For instance I have watched the university students who have no experience with epoxies, fiberglass, Kevlar or carbon fiber take the information from web sites and use that information to build a model that weighs less than 10 lbs powered with a Jett .65 that will lift 40 plus lbs in a successful flight taking off in under 200 feet and landing in 400. They design and build these things with the most basic equipment and minimum of knowledge and technique.
I hate to burst your bubble but this very exacting knowledge you think everyone must hear. Not so, try spending the time better explaining techniques that have value to the guy with no equipment and little knowledge. How to mix epoxies properly, storage, shelf life and what to look for when having problems that can be easily solved without all the bloody industrial equipment. How many people do you think own a vacuum pump? Guys are interested in how to lay the cloth so it stays in the corner. How do I make and use a one time mold for a cowl that’s no longer available. Where is a good place to buy supplies for my small needs? There are lots of topics, tips and tricks you can volunteer that many will actually make use of. Your last post, I cannot think of one modeler I know who would even have a need to attempt the process you describe. I ask what the relevance to modelers is in general when you go on about tools and techniques we will never encounter.
Dennis
#31
My Feedback: (29)
Dennis, are you reading the same thread I am? Take a look at post #3. I only gave the information the OP needed. It wasn't until you came around and started talking about about a product that the OP clearly did not have. He asked if he should follow the instructions that state the cure should be done at or above 70 degrees. We told him yes. It wasn't until you came around much later that this became an issue. If you think what we have said to this point as being overcomplicated then you have no real clue about composites as we really have kept it simple to this point. It's obvious that you feel you have nothing to learn and I really can't care less about this but seriously stop being the class clown here. Rodney has already stated that he feels our information has value and that is good enough for me to continue to answer composites related questions to the best of my ability. If you don't like that may I suggest the door once again.
#33
All I disagreed with were the two points I listed. The rest of the post is direct from the West System web site I cannot take credit for that. As far as knowing what they are talking about I think their expertise far outstrips anything you have to offer. By the way I still disagree with those two points. His remarks were inclusive of all epoxies and that is not true as some are designed to work in less than ideal environments. It wasn’t a criticism or rebuke but an observation from my experience using the West System. Hobby epoxies tend to be similar in that they work in less than ideal conditions. Most problems occur because modelers mix improperly or use epoxy that has been sitting around for years or has been contaminated. The OP is using it for a barrier coat against fuel penetration I don’t see any reference to using it for bond or adding strength. The cure he would get in less than ideal temps would be sufficient.
Dennis
Dennis
8. Post-cure the epoxy if possible. Post-curing can help to complete the epoxy mixture’s cross-linking and boost the epoxy’s physical properties even after a week or two of cold temperatures. Post-curing simply is the process of applying heat to complete or speed the cure after the epoxy has reached a partial cure at ambient temperature. Elevate the temperature of the epoxy and substrate gradually to avoid thermal shock. Although any temperature elevation will improve cross-linking, try to boost the temperature to room temperature (72°F) or warmer. The time required depends on the hardener used, the post-cure temperature and how much further the cure has to go. Generally, higher post-cure temperatures require shorter post-cure times. Do not exceed 140°F and do not remove clamps or load the joint until after the final cure. CAUTION!—Heating a porous material may cause air within the material to expand and “out-gas.” If an epoxy coating applied over the material has not gelled enough before starting the post-cure, bubbles from the out-gassing material may show up in the cured coating. Allow the epoxy to reach a partial cure before post-curing.A variety of post-cure techniques can be used. In some cases your shop will naturally warm itself enough to complete the cure during the day, following a cold night. Outdoors, building a plastic tent to trap solar heat can easily boost the temperature enough for post-cure even during cool weather. Turning up the thermostat, using radiant heaters, electric heaters or electric blankets are the most common way to control the post-cure temperature in a shop. It is not necessary to heat the entire structure if you are working on only a small area. Tents of plastic or insulated board are very helpful for confining heat to specific areas and provide greater mobility with a limited heat source, both indoors and outdoors.
Now they are referring to their own products, but post cures can be performed @ much higher temps and can be accomplished in a normal or in a consolidated state utilizing there system and many other systems as well. Sorry, I almost forgot, you don't want to know this useless information that you will never use.
Bob
#34
Well its a banner day would like to keep the difference of opinion going (its the only one at this time) but I'm going flying with my F5B glider put together without any special equipment or techniques and its 4 years old ticking and still taking a licking. I think I'll take my MXS as well haven’t flown it since last fall. Taking your advice and getting out from behind a keyboard you should take your own advice might put you in a better frame of mind. LTR
Dennis
