RCU Forums - View Single Post - Epoxy curing temperatures
Old 03-08-2014 | 03:27 PM
aymodeler's Avatar
aymodeler
As others have said, you will probably be fine for your fuel-proofing application.
I have the same situation with a relatively cold basement workshop. When building in the winter, after putting together an epoxy joint, I usually bring the assembly upstairs and put it on top of a bookcase (heat rises) to cure overnight.
