Originally Posted by
michael wood
This is the second one I've built and was wondering what everyone used for a control rod for the rudder. I want to move the servo in the servo tray in the fuselage. There is A control rod tube all ready installed there. I am trying to keep the weight down and I know from my last one 4-40 rods vibrates real bad. I will be using A MT35 gas engine. And if I remember right I had to add about 1 1/2 lbs of weight to the nose to balance it. I thought about A pull pull set up. I've read all the post I could find and did not see anything on A pull pull set up
Instead of going thru the trouble of installing a pull/pull system. I would think about just bracing the control rod tube, to keep it from vibrating. Just my personal thought and opinion.
