RCU Forums - View Single Post - Installing Saito engine in Revolver 70 question
Old 03-15-2014 | 10:12 AM
PDF
Default Installing Saito engine in Revolver 70 question
Hello all,
I'm at the point of installing the Saito 100 in my GP Revolver 70 and just saw that the throttle arm on the engine is complete opposite of the installation procedure ( the recommended engine of the ARF is a OS .90 and the throttle are is opposite. The engine is mounted on it's side with the head of the engine facing the right side of the fuse, on the OS the throttle arm would then be oriented on the bottom of the engine compartment and the Saito the arm is on the topside of the fuse. Has anyone installed an Saito in the Revolver and if so could I get some suggestions on how they oriented the linkage and servo to accomadate this alteration.
Thank you for all your help,
Pat
