Funtana 125 elevator setup
Hi,
setting up a Funtana 125. I had an issue with the elevator servos. They sit back to back but the model is not that wide. This is causing the servos on one side to sit a bit off the fuse. I have heard of this problem before. I discovered that the gap is about 3/32". I want to know how other owners solved this problem. Should I put in a 1/16" birch servo frame both sides between the servo and the fuselage to get the servos to sit apart? Or should I get low profile servos? In the latter case, how are Futaba S9551 servos (They are the only ones in Tower's catalog with low profile and in that specification)
Ameyam
