Funtana 125 elevator setup
Hi,
setting up a Funtana 125. I had an issue with the elevator servos. They sit back to back but the model is not that wide. This is causing the servos on one side to sit a bit off the fuse. I have heard of this problem before. I discovered that the gap is about 3/32". I want to know how other owners solved this problem. Should I put in a 1/16" birch servo frame both sides between the servo and the fuselage to get the servos to sit apart? Or should I get low profile servos? In the latter case, how are Futaba S9551 servos (They are the only ones in Tower's catalog with low profile and in that specification)
Ameyam
Ameyam
I am using futaba 3010 servos and went with the shim method. Works just fine. I have not had any problems with the shims on all 4 of my models, S90, 100x and 2 of the 125's. The latter 2 are running a 30cc and a 20cc gas engines. The others are running Saito 1.25 4s.
Not necessarily to go slow in KE. I just felt the rudder was small...atleast smaller than the one on my Yak.
I intend to use 5625MGs, so I am concerned on the thichness of the shim- I may end up using 3/32 both sides and the effect this will have on elevator effectiveness. Anyway, lets see during the build
Ameyam
Ameyam
Since I am located in India, getting SFGs later is a big deal- they cost $17 but cost $84 to ship!. I have a colleague going to the US and I plan to get the SFGs (and servos if needed) through him
I think I am short on servos for the elevator and rudder. So lets see.
Ameyam
Ameyam
