Some ESC's (electronic speed control)with a built-in BEC (battery eliminator circuit)(regulator)come with a slide switch already installed that will disconnect it from the receiver disabling the planes controls and throttle until the switch is turned on. This won't keep the battery pack from being drained. They also make a battery disconnect switch or safety switch that disconnects the battery from the ESC until the switch is plugged in(turned on).
