RCU Forums - View Single Post - Installing Saito engine in Revolver 70 question
Old 03-17-2014 | 02:30 PM
PDF
Thanks again, I'll give it a go. Granpoopa the reason I'm rotating it is because the throttle servo per instructions is mounted behind the fuel tank and the linkage runs besides the tank and out the firewall. That to me means I'd have to have the throttle linkage coming out low just under the engine mount. My Saito having the engine mounted on it's side with the exhaust and heads facing out the right side of the cowl has the throttle linkage up toward the top of the engine compartment. Did your Saito line up like mine and if so how did you route the linkage.
Thanks again,
Pat
