Originally Posted by
flyinwalenda
OK . I just programmed a plane on my heli radio and programmed a mix for thro-thro @ -100/-100 and set it to a two position switch with the offset maxed out @-125 and it works .
With the switch ON the plane is active all but the throttle. Turn the switch off and the throttle is now active. Very similar to heli throttle hold.
SHD3920, depending on what radio you are using you may be able to do this
No chance. I have a simple JR Max6.
