RCU Forums - View Single Post - FUNSONIC FS52 / projet Help
Old 03-20-2014 | 03:35 AM
Tampaflyer
My Feedback: (42)
thanks , to everyone for helping. I did contact Carlos at RTI. Great guy. He said it is likely that the fuel pump is not getting a signal to start running because of temperature.
while he doesn't work on this brand, he said at look at those areas.
I was also informed to look into loose connections as a possible reason for the cause. I do get some rpm readings once spinning. but just get nothing when spinning by hand.
I may set up a video on the next run up, try. it would help to see it, .
